Results 1 to 7 of 7
Thread: I got a new furnace!
    I have some very good friends. One of them works as a wood shop teacher and heard about a furnace that was to be discarded in the district. He luckily remembered me.
    Its a Johnson 510 crucible furnace. Interestingly, it has a down draft side exhaust. Twin natural gas burners.
    The interior has seen heavy school use, if you know what I mean. It had about 3" of dross that seems like it turned into alumina against the bottom and walls. I got it out. It came with a #10 crucible, if I am not mistaken on size. Just going by what I saw of another on ebay. The crucible has also seen school use and has a generous coating of aluminum. The pot still seem sound though. I will fire it and clean it out.
    My friend also got me a new crucible that seems like the same size.
    Picture time!
    [img]http://4.bp.blogspot.com/-S4zhQc_Z1Co/UFP-r4rRJ5I/AAAAAAAAAWw/aV1nO9jzi3w/s320/IMG_1325.JPG/img]
    I am not sure what route to go with this thing. I am thinking of using the lower burner port for a waste oil burner. Before I do, does anyone have experience firing with natural gas. Anything I should know?
    Another though that entered my head was the idea of a evaporator burner mounted in the exhaust, but you'd still need to start it somehow.
    Any ideas for anything are welcome.
    Bill
    Use those coffee makers with the spout out the bottom to preheat you oil!
    My foundry: http://www.alloyavenue.com/vb/album.php?albumid=1
    My waste oil burner:http://www.youtube.com/watch?v=NwpKCsiWKls
    Metal casting video:http://www.youtube.com/watch?v=8ui24..._order&list=UL
    My website : maniacmechanics.blogspot.com
    Senior Member metalshop's Avatar
    Oct 2010
    Charlotte, NC USA
    1,038
    9
    ThAT IS GREAT bILL!! Oops my caps were locked. Nice score...I am sure you will put it to good use.
    Dave D
    Build the Kwiky all fuel burner: new video: http://youtu.be/E-l21wQ6X-E
    See my projects: http://backyard-foundry.com
    Join the Lost Foam group on alloyavenue: http://www.alloyavenue.com/vb/group.php?groupid=3
    Dec 2006
    SE Michigan
    592
    2
    Great score Bill, you have got some very good friends. I wish some of my cronies would drop something as nice on me. Keep us posted on how it works out.
    hobiejack
    Apr 2011
    Choctaw, Oklahoma
    1,518
    talk to BOB S and leave it on either propane or NG if you have it. That furnace is designed and built to burn gas, yea I know your going to say oils free or cheap
    Senior Member Bob S's Avatar
    Saginaw, Mi
    1,634
    Quote Originally Posted by dallen View Post
    Yes, I have this same furnace which was mainly designed for a cast iron pot placed on the top opening for melting low temperature metals like zinc, pewter or lead that were ladled out to the molds. However it also can be used with a crucible for melting aluminum or brass although I have never tried to melt brass in mine and mine will take a #16 crucible. The problem with using it for crucible melting is it's a task to preheat the metal and add it to the crucible and also to keep an eye on the melt, requiring the lid to be swung out of the way each time. To have it work correctly the lid must be in place.
    Sorry for this fuzzy picture.
    Main gas shut off on top and the pilot light shut off on the side and the swing door on the blower to balance the flame.
    The type of pot that was placed on top.
    Flame pattern used with NG.
    This furnace is a back up for me now and use it mainly to preheat my brass crucible when I switch from aluminum to brass which I then place the aluminum crucible in to cool down it. With lid in place the crucible doesn't cool down as fast as in an open vent type unless to cover the vent each time when finished. It's a very simple furnace operate and should be easy to maintain. I think you will complicate the furnace's function by trying to use it with waste oil. Bob
    Interesting. This furnace did have a crucible with it and was obviously used for aluminum. How long would it take for a crucible of aluminum to melt?
    Also, what sort of pressure does it need to operate?
    Aug 2012
    N.C. North of Charlotte, United States
    213
    Niiiice score. Wish I had some connections like that one!
