Results 1 to 9 of 9
Thread: Flasks
    Flasks
    Has anyone found a source for professional Snap flasks and jackets, I have always seen hugga molds(SP?) I cannot find anything anymore save a rare used one. and I think it is time I invest some cash in flasks
    FC
    Guest
    If you have a welder you can make your own out of metal channel. Or, you can make them out of 2x's w/hinges, latches and guide pins (or key lock configurations). All utilizing scrap stuff we typically have lay'n around a shop.
    The possibilities are endless... even round flasks.
    Try General Foundry for stripper snaps.
    Murray
    5:55 is a state of mind
    Have you ever had the sand fall apart during a pour when using a flask?
    How do you put weights on the sand without a flask around the sand?
    Am I missing the point on how to use them :?
    try to find some kind of steel plate that is heavy, but will span across a larg section of the mold, distributing its weight evenly. Sometimes I use a piece of plywood thats big enough to span the whole mold with a weight on top of that. it keeps the sand flat without putting extra weight in the center...of course, I dont have a snap flask, just regular ones, but in theory should still work about the same...
    FC
    Guest
    Just like this...
    after an extensive search i found this
    http://hinesflask.com/
    BTW using a snap flask without Jackets, is Very dangerous
    Yep Hines are great snaps like I said try general foundry for "Stripper" snaps, pretty seriously widely used. As far as jackets you buy one and duplicate it.
    Murray
    Quote Originally Posted by HT1
    Hines flasks are AWESOME. Pricey, but they take a ton of abuse and just keep going. I've got 4 or 5 in various sizes.
    I used my 12x16 today:
