Page 18 of 18 FirstFirst ... 8161718
Results 171 to 176 of 176
Thread: Simple draft and full mold patterns
  1. #171
    motzingg, The Excelsior link is neat, thanks.
    I tested the pocket pattern and the plug for the core box. The pocket was a little large, I may have added too much material for the shrink because the gap around the core pattern is excessive, but the fins pulled OK and the exhaust core mated with the core print. This flask is too small for this casting, but it is quick to ram up for these trials.
  2. #172
    2,400
    OK, another stupid question....But where is the intake??
  3. #173
    This is only the pocket. It will be cast in the cope. The combustion chamber is in the center and the projection on the right above the exhaust is the intake core. The intake valve, seat, spring and rocker arm are carried in an assembly that locks into the head with a retaining ring. Look back at the previous photos of the pattern for the head and intake pocket. They will be molded in the drag. This is just the start, and the rear head is different as far as the exhaust port angle is concerned.
  4. #174
    @DavidF
    I believe this is an atmospheric valve engine, the pushrod drives the exhaust open and closed from a single cam, and the intake valve opens automatically on a light spring to draw air through the carburetor on the down-stroke which is not the power stroke. Like a hit-and-miss only without the governor mechanism so it fires every revolution.
    Sandcrab, do you do a plaster test-pour the way BobS has shown in pictures, or do you just measure/eyeball the cavity? I think i need to build a small molding flask for exactly the purpose you are describing here- less overburden that you need to pack, move and worry about. I naturally assumed my first patterns would pull right out of the sand and work perfectly on the first try, and I have found that to not be the case, ha ha!
  5. #175
    Splendid work Sandcrab.
  6. #176
    I moved this project down to "1914 Indian heads". Moar pictures.
