Results 1 to 10 of 11
Thread: Double pouring a single casting.
    I have just begun casting aluminum and I want to cast some larger pieces that require more material than my largest crucible can hold. My question is whether or not I can double pour a single casting and would there be a separation or weak bond between the two pours. Thanks for any information that can be provided.
    1,156
    Absolutely will be a joint with little to no bond.
    Time for a bigger crucible/furnace.
    Might you be able to strategically separate the design so that you could pour it in two parts, then have them TIG welded together?
    Roger
    Forget about this. Molten metal will not 'weld' automatically to cold metal, unless you preheat it strongly.
    Welding however rails works this way, but the rail butts which have to be welded together are strongly preheated to 1000 C and the liquid steel is much hotter (2500 C) than the melting point of iron (1530 C) due to the immense heat of the thermite reaction, resulting in a strong weld.
    In your case, as other say, order a larger crucible and / or build a larger furnace.
    Thermite welding! Cool process.
    3,016
    Are you guys sure? I think I have seen double pours done commercially.
    1,156
    In industry, pours are often made with multiple ladles, but always simultaneously.
    Quote Originally Posted by Wolfcreek-Steve View Post
    Indeed, more ladles with steel are used at the same time as a source of metal, here a nice example of casting of a steel ring:
    https://www.youtube.com/watch?v=KdO8vuh3QpI
    Hudson shoreline
    644
    There was a video of Nepali casters doing a double crucible pour I came across a few years ago. Two pouring teams, one feeder. As one crucible finished the next started pouring , with a slight overlap. It takes a talented, practiced team.
    The video may be linked from a discussion about ashanti style investment casting some years back.
