Results 11 to 15 of 15
Thread: Cafe Racer Bicycle
    Quote Originally Posted by Robert View Post
    I just test rode this! Robert
    Tell us more. Range? Weight? Top speed? About the wheel/hub motor? Will you add pedals? Going to stay with those brakes?
    Quote Originally Posted by DavidF View Post
    Like a disconnect or one for if you fall off??
    Personal Watercraft tether?
    2,579
    Pressure switch on seat??
    Senior Member Robert's Avatar
    Sep 2008
    Charlotte, Nascarolina
    2,988
    I mean a disconnect in case the controller runs away. If (when) I fall off, the throttle spring will just return it to 0. My plan is to put a 30 amp switch on the battery. It will not be switched under load unless there is an emergency. I think that will work fine.
    The motor is 1000 watt Chinese import. The wheel/motor weighs 16 lbs. The battery less than 10. Top speed is about 28 mph. Range should be 10-15 miles per charge without pedaling.
    I just finished the bottom bracket:
    Neither the frame or the forks are setup for calipers so it is V brakes for now. If I use this thing a lot, I may go to disc in the future. I would have to change out the fork and weld mounts on the frame.
    Next: finish the spindle. Change the tire for MTB tires. Start on a cool battery box. Need to find or cast a bullet headlight and a seat!
    Robert
    "Whether you think that you can, or that you can't, you are usually right."
    - Henry Ford (1863-1947)
    Forklift Project
    Sand Mixer
    Sep 2016
    Oklahoma Panhandle
    29
    I like it. Just put a kill switch on the handlebars. If things go nuts you cut the power to the entire thing before it dumps you.
    Most people stand on the peddles when going over a bump so a seat switch would be bad.
    Sep 2008
    2,988
    The brake handles have kill switches that feedback to the controller. I also want a master power cut off. Hence the 30 amp switch.
    I feel some casting coming on for the seat and the headlight housing unless I can source something more easily.
    Robert
    Forklift Project
    Sand Mixer
