Results 1 to 7 of 7
Thread: Evaluation of PolyMaker PolyCast(SP801C): A3D printer filament for investment casting
    This is a reformatted version of my post on reddit
    TL;DR Album
    I recently got a roll of Polycast SP801C, which is a variant of the polysmooth resin(PVB), but it is tailored for investment casting metal parts. The special thing about this filament is it prints as easy as PLA, burns out clean(testing soon), and most of all, it can be smoothed/ dissolved with alcohol. I have also noticed that it cuts and sands like ABS, which is a nice change from PLA.
    I have been printing and smoothing the SP801C with good results so far.
    The diameter measured 1.75mm exact and is very circular(better than can be measured with calipers)
    The printing characteristics are great, nearly identical to PLA with very minor stringing, but excellent bridging, and support structure breaks away perfectly.
    I had some trouble with bed adhesion on glass coated with Mod Podge (PVA glue) at 45C but increasing the temperature to 60C with a 10mm brim, or 75C without a brim solved it for me. I've been running the hotend at 215C for the first layer and 205C for the print. My printer has a large 0.8mm e3D V6 nozzle because I typically print big and fast for functional parts, where layer lines aren't important; for the fine stuff, I switch back to the 0.4mm nozzle.
    I have tried smoothing the Polycast by putting the parts in a ziplock bag with a couple ml of isopropyl alcohol(IPA). I Inflate and seal the bag, then shake for about 10 minutes, until the parts look smooth. I let the parts dry on a piece of wire mesh for easy removal once hardened. This approach is a bit ham handed and Iv'e had IPA leak in to the model through an eroded gap and cause a temporary squishy spot. To be fair, my method probably erodes the model more than the official "polysher" would.
    On beefy 0.4mm layers it significantly reduces the layer lines, but they are still present as very shallow and gradual undulations. The surface has a nice high gloss, and scraping my fingernail over the layers does not produce the typical "zipp" noise of a normal print. Although it is not completely aesthetically smooth, this partial smoothing should be beneficial for the casting process, removing all of the sharp creases that normal layer lines have, which should reduce damage to the investment material, reducing inclusions in the castings.
    On normal 0.2mm layers the smoothing works completely, the layers merge into a smooth glossy surface.
    Benchy Smoothed print defects still show, but the surface is smooth
    3D scan bust smoothed
    Sprue tree smoothed
    Sprue tree closeup
    One additional benefit of the SP801C is being able to use IPA to solvent bond custom 3D printed sprues to the models. I printed some custom sprues that position the model accurately within the confined space available in the investment flask, and also form the pouring funnel after the plastic is burned out of the investment. Being able to print the sprues separately from the models allows each to be printed in their best orientation, sometimes eliminating the need for support.
    Benchy Sprue
    Sprue tree assembly
    I am hoping to Invest the parts this week, and burn-out then cast this weekend. I will provide another update after casting.
    Sprue tree and 3D scan next to flasks
    2,344
    Ill be looking forward to seeing the casts.
    A calm sea does not make a skilled sailor....
    Me too.
    This casting session will be the first time using:
    *Actual R&R Plasticast vs. 33:66 Plaster sand mix
    *Actual electric burnout furnace vs gently blasting it in the propane fired melting furnace for an hour till it stops flaming
    *Using a vacuum plate vs gravity feed
    David, your process and results have been a huge inspiration. Thanks!
    2,344
    Thanks
    Very nice evaluation!
    Can't wait to see the cast!
    I'm investigating 3d printing and ceramic shell casting, will definitely look into this PolySmooth (hadn't heard of it till now...) next to the moldlay filament (have you tried it before ?)
    I haven't tried moldlay, but I've been curious.
    I tried print2cast wax filament, but it was giving me trouble and I didn't get much time with it.
    As far as printing quality, so far polycast has been superb, but we'll see how well it burns out.
    I might get a roll of polysmooth(sister product) when it's released, just for printing, that's how nice this stuff prints.
    I don't have any XP with ceramic shell, but the Polymaker's demo video shows Polycast being used for ceramic shell casting stainless steel.
    Best of luck, I know some day I will go down the ceramic shell rabbit hole, especially since I have an electric furnace now.
    Can't wait to see your casts! Hope it burns out nicely!
