Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: Making 85-5-5-5 brass
    Senior Member Robert's Avatar
    Sep 2008
    Charlotte, Nascarolina
    2,926
    I made this today. This particular top spins forever:
    R
    "Whether you think that you can, or that you can't, you are usually right."
    - Henry Ford (1863-1947)
    Forklift Project
    Sand Mixer
    Numb (dumb?) Question: does this alloy make 'passable' bearings/bushings? As in "could I cast bushings with built-in mounting flanges, given suitable raw materials?"
    Note that alteration of the mixture is acceptable, i.e. less zinc / lead and more tin. Note also that I'm not picky beyond 'it shouldn't be a complete headache to cast or machine, and work *passably* as a bearing, too.'
    Ouch! That stuff's hot!
    den, I took a quick look at some of Ammen's mixes and the closest to the 85 triple 5 is bearing bronze at 80 copper and 10 each of lead and zinc, or journal bronze with 82-84 copper, 12-14 silicon, 2-4.5 zinc and less than 1 of lead and iron.
    I have no idea as to the ease of casting.
    If you think you can't do it, you're right!
    Sep 2008
    2,926
    I'm pretty sure you could make and cast any bearing alloy you wanted. There may be a little porosity but that should not hurt a bearing at all. I have cast bronzes with Cu content ranging from 65-95%. I have used various alloying metals.
    C932 bearing bronze is very close to what I made here:
    Bearing Bronze (C932), a/k/a SAE 660
    Minimum Properties Ultimate Tensile Strength, psi 35,000
    Yield Strength, psi 20,000
    Elongation in 2" 10%
    Brinell Hardness 65
    Chemistry:
    Copper (Cu) 81.0 - 85.0%
    Tin (Sn) 6.3 - 7.5%
    Lead 6.0 - 8.0%
    Zinc 2.0 - 4.0%
    Robert
    Forklift Project
    Sand Mixer
    3,026
    One question you have to consider is the speed of the shaft in the bearing. Having been in the old time wooden boat building business when I was younger, I had to pour bearings for my machinery sometimes, most of which ran using wide flat belts on two inch shafts run at a fairly low speeds. Damn near any bronze or lead/tin alloy did fine for that. If you are running a small shaft at 3000 rpm, the requirements are more particular. You want a tin bronze with some lead in it, or a Babbitt metal with a lot of tin.
  6. #26
    Sep 2008
    2,926
    Good points. Also, some bearing are sintered and oil impregnated.
    Robert
    Forklift Project
    Sand Mixer
  7. #27
    3,026
    And there are some definite disadvantages to each: Babbitt and bronze.
    • Bronze is cheap. Maybe three dollars a pound, but more difficult to pour and to machine.
    • Babbitt is costly (tin is around 20 dollars a pound, and it takes more pounds for a given volume), but it is easy to machine by hand for a perfect fit.
    R
