Results 1 to 5 of 5
Thread: question about propane regulator setting
    Nov 2011
    micanopy, florida
    9
    I have a burner that is fueled by a 20# propane tank. I haven't used it in about 2 years and now I can't remember the setting I used for the propane regulator. Can anyone recommend a PSI setting.
    1,311
    depends on your burner type and size
    Generally speaking, I never even look at my pressure gauge, I start off with just enough pressure to get a stable flame then ramp it up until I like the way it's burning.
    Nov 2011
    micanopy, florida
    9
    Quote Originally Posted by rocco View Post
    Thanks for the advice, guys. I'll just do some trial and error.
    1,897
    take a look at the flame from the burner and play around adjusting the pressure and observing the flame. you can get different furnace atmospheres by adjusting the fuel to air ratio. The majority of times you want a near neutral flame. There has been some discussion here regarding gas pick up of metals and how the furnace atmosphere contributes to that. In my experience, I know that aluminum likes to pick up hydrogen gas and that is the porosity you see in castings, so adjust your regulator so that you are on the oxidizing side of a neutral flame. Typically copper alloys pick up O2 so I would run my burners a little rich. Hope it helps.
    Kent
