Results 1 to 7 of 7
Thread: Why is my sodium silicate not binding?
    I mixed some sodium silicate today and unsuccessfully tried to make a core. For some reason the sand mixture wouldn't bind.
    Any reason why it wouldn't bind? Maybe too much sodium silicate? I had the CO2 pumped for a while. There was no spot where it was hard, the thing just crumbled.
    I've used this mixture before, but not for such a big core (the diameter was about 3.5in and the whole thing was about 8in. The sand has been in the outside shed and it's been freezing temps lately. I made this in my house so it was in room temp.
    I ran out of the sodium silicate so I'll have to wait until I get more.
    Any ideas?
    1,348
    You had the CO2 pumped for a while???, too much CO2 at too high a pressure will cause the sand to crumble, but it will get hard ... after gassing did the sand still feel sticky/ wet or did it get dry... only two possibilities I can think of off my head, bad SS or overgassing
    2,616
    I've been wrestling this myself a bit. My main two thoughts for my problems are that the SS has gotten old, or I am mixing it too long and its drying out before I gas it. I will be replenishing my supply shortly and eliminating the possibility of the SS being old.
    What ratio are you mixing at?
    1,348
    here is what the Navy has to say about CO2 sand... good info Sorry it is sideways, save it rotate and enlarge
    Ugh, my mistake. I had two tubs of playsand and I forgot one of the sand was premixed with bentonite which I haven't used in ages. They both look so alike when dry!
    I just tested a small sample with whatever I had left of the sodium silicate and the real playsand and all is good again!
    This is the SS that I've been using. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 The cost wasn't bad and it has worked great. As for size? I have made the whole mold out of SS say a 9"x9"x8" flask. I'm not really good with weighing it... I mix about 1/2 a 5 gallon bucket of sand with just enough so that it feels like greensand (anymore and it's a pain to get out after the cast...like hammer and chisel pain ). Gas it and let it set overnight. Been happy with the results.
    The stuff I used in this video came from a pottery supply place, it costs about $15 a gallon, the CO2 came from a 20oz paintball canister.
    BTW, this video was shot in a single take, no cuts, no editing, it shows the whole process, start to finish, in real time.
