Results 1 to 4 of 4
Thread: Refractory: Ceramic wool, firebrick, or castable?
    Hi guys,
    I'm beginning to do the research end of a project to build a furnace capable of melting cast iron. My question is, what are the pro's and cons of the three general types? I've seen some people make furnaces of just Kaowool or the like, how long would this last?
    Benjamin
    3,118
    Not very long, melting cast iron. The highest temperature rating of any ceramic wool I have found is 2700 F. I use it to line my furnace lids. I melt bronze, and those wool lids need frequent repair.
    One factor though, in favor of ceramic wool, is that when its temperature limits are exceeded it does not fail catastrophically as does a castable. Rather, it begins to singe and frizzle like burned hair.
    Thanks for the continued help Richard. This forum is a great place!
    I guess I'll rule out using only ceramic wool. How does firebrick compare to castable, in terms of longevity?
    Canoga Park, CA
    569
    You could still use wool on the outside if you want to boost efficiency a little or reduce the close ambient heat in your work area. Check out indiscriminate scavenger's posts. He's the Ironman in my book and has much experience with iron furnace longevity. Also iron will really gunk up your furnace if you use it for other metals.
