Results 1 to 7 of 7
Thread: a tour de force in wood
    Hudson shoreline
    651
    I'm a sucker for sneaky geometry, a lot of why I love molds. Years ago I saw one of these things on eBay and decided I needed to make one. It's an old Chinese form called a one-plank-stool. Guys at work were bugging me about it, so I dusted it off. It is a low folding stool carved from a single chunk of wood.
    Edmonton, Alberta
    130
    Nice work, is that all carved with a knife?
    Hudson shoreline
    651
    Made with chisels and saws , primarily. One of the more challenging aspects was getting the proportions right for the action, from a photograph. As I recall, it involved tracing off the screen on plastic film and sliding around the cut out shapes. This was back in the days of dial-up, no printer available.
    I agree, quite intricate, and one has to really plan ahead. Now, you want to REALLY impress someone? Cast on up in aluminum.
    (Probably can't be done.)
    Roger
    1,499
    You probably shouldn't say that around these parts!! (No I'm not up for the challenge!)
    Hudson shoreline
    651
    Actually, casting would be fairly straightforward. Cast two non interlocked pieces; build the interlinking piece in wax through the precast pieces (refractory coated} invest and cast; build the last piece in wax through the previous pieces (coated), invest and cast. Easy peasey.
    Make it in lost foam... get it working, take it apart and cast!
