Results 1 to 4 of 4
Thread: Regarding remaining plastic in cavity after using Plastic(ABS)
    After burn out there is remaining plastic in cavity after using Plastic(ABS) as investment casting.
    Please suggest
    1,171
    You need more time in the burn-out oven and/or more heat.
    What is the size of the flask you are burning out?
    What temp are you going up to?
    How long are you holding at this temp?
    why are you using ABS instead of PLA? ABS has a higher melting point. that may be part of the problem, make sure you are heating the flask high enough and for enough time.
