Page 1 of 4 123 ... LastLast
Results 1 to 10 of 31
Thread: Unicorns & Green Bay
    Canoga Park, CA
    603
    Had a busy weekend on this and figured I'd start a new thread as its not going as planned. Maybe admin can move my first post over here from "What did you do..." Anyway, got the first unicorns filleted with toilet ring wax.
    Whipped up the Green Bay Packers logo foamies. The left is right off the hot wire and the middle is hand sanded with 100 grit to get the high spots then 180 for finish.
    Mudded them all up.
    Rethought the unicorn foamies. Adding slugs on the feet, tail and horn to help fill.
    First casting of 3 foamies not so good for unicorns and oval.
    Cut the sprue off the other 2 unicorns and replaced individually with white foam in 2 postures. Added runners to the oval and added a second "G".
    Still short on the unicorns.
    I have 2 unicorn foamies left so think I need to feed the tail, legs and horn directly with some extra runners and stick with the horizontal posture, though the bottom side leaked somewhere. Any other suggestions are welcome. Also contemplating a plan B. My grand niece also likes dolphins which would be easier to cast. But I'd really like to get one of these unicorns right. On the Packers logo the plan is to polish the face and back of both pieces and paint the edge of the "G" green and the oval yellow. Then drill a small hole and suspend the G in the oval with fishing line like a mobile.
    Just copy the post over there and paste it in a new post here.
    I have been telling people for several years now to stop posting your projects in the "What Did You Do ..." thread. After a day or two they are lost and essentially gone forever from the eyes of the readers.
    Canoga Park, CA
    603
    Very sorry. Didn't plan for it to go on originally. Red text noted.
    Worked on a new set of templates and foamies over the weekend. Hope I'm not being too ambitious. Need a little more sanding then fillet the corners and bad spots then sprues and coating. With my template method its just as easy to make several at a time in case of fails along the way. Still thinking about how I'm going to feed this. Planning to sand/grind the horn to shape after casting but made it oversized to help fill. Mainly concerned with filling the tail.
    http://
    Bret Favre is rolling in his grave....
    Dec 2015
    Fort Worth, Texas
    130
    He died? I thought he just retired and made Wranglers commercials...
    1,171
    He's far from dead, was in GB a month ago.
    CD can you not hang the unicorn off the side of the sprue, just as you have it prancing in the photo (upside down of course).
    first the back feet against the sprue, then the belly, then up between the legs to the horn
    Hi Cactusdreams,
    I would suggest you use a taller sprew to give greater "hydrostatic" pressure in the liquid metal to force it to the extremities of your pattern. Also pour fast!
    Hope this helps.
    Peter.
    Could try a taller sprue.
    Could also try giving the legs their own runners off the sprue, that way they get a better fill and aren't as likely to shrink cavity the main body.
    My Oil Burner
    Canoga Park, CA
    603
    Thanks all for the suggestions. You're all pointing to where I think I'm going. Feed the extremities directly and bury it a little deeper. I kept the riser full as I was pouring so can't go any faster. But it would sit for a moment then burp and drop a couple times, not one continuous draw down the sprue. Poured on the hot side, around 1450ºF.
