Page 34 of 34 FirstFirst ... 24323334
Results 331 to 339 of 339
Thread: r4z0r7o3's Crucible-furnace lifting mechanism / transport-stand.
  1. #331
    1,069
    Extra! Super! Duper! Exciting work!
    Drilled a 1-1/8" hole in the back of the control box. Then I used an online calculator (somewhere) to calculate the angles and distance needed for that 1" offset EMT conduit bend. (20* and 2-in. IIRC).
    Printed out an updated schematic (minor changes/additions):
    Printed out an updated wire number / terminal position key (a.k.a. Screw who where):
    Code:
    Main Enclosure
    110v Mains #0001 -> Sw1 -> #0003 10A Fuse -> PSU
    0v Neutral -> PSU
    GND -> Chassis -> Ain3 (below)
    Motor Black -> #0008 && #0011
    Motor White -> #0009 && #0010
    Motor GND   -> Chassis
    Control/Terminal Box
    Wire #  A IN                         Wire #  A OUT
    #0006   1 63v+ PSU (out 1)                   1 E/D SW2+ (inp)
    #0004   2 12v+ PSU (out 1)                   2 N/C
            3 Chassis Ground (lug)               3 Chassis Ground (Y out)
    #0005   4 12v- PSU (out 1)                   4 Dout3 (Y inp)
    #0007   5 63v- PSU (out 1)                   5 E/D SW2- (inp) && Dout3 (Y inp)
            B IN                                 B OUT
    #0013   1 U/limit SW4- (out)         #0009   1 Motor - (Y inp)
    #0015   2 D/limit SW5- (out)         #0011   2 Motor + (Y inp)
            3 E/D SW2+ (out)                     3 Snub D1+ (inp)
            4 E/D SW2- (Y out)                   4 Snub D2+ (inp)
            5 E/D SW2- (Y out)                   5 U/O/D SW3- (inp)
            C IN                                 C OUT
            1 Snub D1- (out)                     1 U/O/D SW3+ (Y inp)
    #0012   2 U/limit SW4+ (out)         #0008   2 Motor + (Y inp)
            3 Chassis Ground (Y inp)             3 N/C
    #0014   4 D/limit SW5+ (out)         #0010   4 Motor - (Y inp)
            5 Snub D2- (out)                     5 U/O/D SW3+ (Y inp)
            D IN                                 D OUT
            1 U/O/D SW3 UP+ (out)        #0018   1 U/limit SW4+ (inp)
            2 U/O/D SW3 DN- (out)        #0017   2 D/limit SW5- (inp)
            3 Chassis Ground (Y inp)             3 Aout4 && Aout5 (Y out)
            4 U/O/D SW3 UP- (out)        #0019   4 U/limit SW4- (inp)
            5 U/O/D SW3 DN+ (out)        #0016   5 D/limit SW5+ (inp)
    Connected all the wires to the "input" (left) side of each terminal...
    ...and then to the "output" (right) side. Applied the clear plastic protective covers on each.
    Then the real fun began, continuity testing and measuring certain connections...
    ...comparing to expectations based on measuring the PSU outputs and Motor coil resistances. Also checked all the switches were actually switching. Here's the list:
    Code:
    All switches open
    (limit switches normally-closed)
    A1 -> A5:          About 6.5kΩ
    A1 -> B3:          N/C
    A2 -> A4:          About 5kΩ
    A1 & 5 -> B1 & 2:  N/C
    A1 & 5 -> C2 & 4:  N/C
    B3 -> C1 & 5:      700kΩ
    C2 -> C4:          About 1.5Ω
    D1 -> D5:          About 1.5Ω
    D2 -> D4:          About 1.5Ω
    All switches On & Up
    A1 -> D2:          About 6kΩ
    A1 -> D5:          About 6kΩ
    A1 -> D4 any limit:  N/C
    All switches On & Down
    A1 -> D4           About 6kΩ
    A1 -> D1           About 6kΩ
    A1 -> D2 any limit:  N/C
    Actually found a few problems (swapped wires) to fix, and a few unexpected things (that turned out to be normal e.g. reverse leakage through snubber diodes).
    Note: The floating terminal blocks are only temporary. I needed to see where I could comfortably mount them w/ the wires attached, b/c they're not all a uniform length.
    Finally, I wheeled it outside, into the middle of a big field. Plugged it in...
    ..turned it on...
    ...flipped the "up" switch...
    ...and...
    Kidding...actually I'm too scared (and hungry) to do it now, soon though
  2. #332
    2,097
    I've been cobbling electrical systems for bordering on decades. Everytime i turn anything on that I made, I cringe just a little bit...lol.
    The death of fear spawns complacency.... <--write that down.
  3. #333
    1,069
    Ha, U sure you don't mean "Fear of death"
    So I figured the PSU is protected by a slow-blow fuse, but there's nothing protecting the motor really.
    So I just ordered 20x (each) of three different sizes of PTCs (resettable/thermal fuses). I can gang ones of the same rating, in parallel, to (more-or-less) dial in the amperage I want them to cut out at. These will protect the motor from excessive current and heat, over a given amount of time.
    For example, the biggest one I ordered is rated for 650ma of holding current, and 1.3a cut-out (60v rated). If I put 4 in parallel, that means they'll allow up to (0.65 * 4) 2.6 amps through (basically forever). However, anything above that and they'll start getting hot. The closer the current gets to 5.2 amps (1.3 * 4) the faster they heat up (nearly instant at full load). The hotter they are, the more resistant they become to current. Let them cool down, and they work normally again.
    Bottom line is, if something mechanical goes wrong, like the limit switches failing, or my head gets stuck in the rails. That will cause the motor to draw more current, especially if it's at a dead-stall. The PTCs heat up, and limit the current to the motor (or stop it outright). Remove/fix the problem, let the PTCs cool off, and it's good to go again. So they're a cheap (like $0.25 ea.) way to control both the duty-cycle and protect the contraption from harming the motor, w/o having to run out and find a replacement fuse.
    While I wait for delivery, my plan is to double-check my wiring with a small battery-pack and some LEDs (I have lots). I'll just disconnect the PSU (I already know it works), and connect up the battery leads. Then I can test it out easily w/o fear of leaving shit-stains anywhere, or explodicating anything expensive
  4. #334
    1,069
    Dasblinkenlights! While waiting for the PTCs to arrive in the mail, did some tinkering that involved 6-volts, two LEDs and a pot. (no! not that kind!). The LEDs are back-to-back, with the pot limiting the current off the common legs. The point being, if the voltage is the right way around, the blue LED goes off. If the voltage is flipped, the red one fires. So, then, it was just a simple matter of swapping the PSU output with a battery-pack and the motor leads for the LED thingy.
    In the red/black spagetti box, I stuck my DMM between the PSU's + lead, and it's terminal block connection. Flipped it to measuring miliamps, and turned all the power switches on. Can't tell you how excited I was to see all 0's on the display (no leaks, no shorts) and nothing releasing even a hint of magic-smoke. Double-checked the voltages, and all was as expected.
    For the grand-finale, I toggled the selector switch up and down.
    Yay!
    So it seems I've probably hooked everything up right. When the PTCs arrive, I'll drop them in and go (with lots more confidence) into the real test
  5. #335
    I am sure you will get it sorted out soon.
    Smarter, not harder.
  6. #336
    2,097
    So the LED rig is just to do a polarity check on your wiring...?
    You can do that with your DMM.
  7. #337
    1,069
    Not at the same time as measuring current, I'd need a second DMM, and one with a backlight that lasts more than 10-seconds :S I also wanted to test the circuit out under load, snubber-networks do funny things sometimes.
    It was a quick build, and now have a little blinky doo-dad (with alligator-clips) I can use elsewhere (hence the pot., instead of a resistorb).
    Actually that reminds me, I saw a 3-5mA difference between the blue/red LEDs. I think that's just because they're different types and colors, but I should verify.
  8. #338
    3-5mA sounds about right for the different LED types. Red one normally light @ about 1.5V the Blue (green,UV,white) light at about 3V. @ 500Ma they get Really Really Bright.....but only for a split second... then the go forever dark
  9. #339
    1,069
    Quote Originally Posted by CrazyBillyBob View Post
    Damnit, I musta blinked, didn't even get a weird smell
    During my soldering + nom-nom-samitch break today, I got 5x 400mA PTC's down in a perfboard, wires on each end and crimped-on connectors. So, 5 * 0.4 = 2a holding current (motor rated for 4.1a). Got lots of holes left in the perf-board to add in more as needed. Managed to snap a few pics along the way before hadda get back to the day-job.
    Plan is to stick it in-line somewhere, probably in the control box (further away from heat). Somewhere I can screw it down with some standoffs.
