Page 2 of 15 FirstFirst 123412 ... LastLast
Results 11 to 20 of 143
Thread: Air cooled 2-cycle motorcycle racing cylinder
    Dec 2014
    San Francisco, USA
    53
    "IANaTST (I am not a two-stroke tuner), but won't the increase in volume of the transfer ports reduce the crankcase compression? Also, the turbulence may be deliberate to improve scavenging the waste gases and cylinder filling, two-strokes are complicated like that, four-strokes I can get my head around valve timing / overlap / port shapes, but two-strokes? Black art"
    High crank case compression and poor streamlining in the transfer passages = old school, high rpm power, narrow power band, low BMEP engines.
    You want turbulence in the combustion chamber but not the transfer flow passages, that later just restricts flow of the fuel/air charge entering the engine...
    Lower crank case compression, streamlined transfer flow with ports aimed properly for good loop scavenging = modern, wide power band, high BMEP engines, these motors rely more on pressure waves in the pipe to drive scavenging then crank case pressure... the smooth flow n the transfers is one of the major improvements comparing engines of the 1960's/70's to modern engines...
    "Early two-strokes had deflector pistons to direct the transferred mixture towards the cylinder head to help with scavenging, modern flat-top pistons I assume need the transfer ports' flow characteristics to do the same job, how they do it? Pass!"
    Those are reffered to as "cross flow scavenged" engines, and still see wide spread use in out boards... here we are dealing with a "loop scavenged" engine. the loop scavenged design is generally makes more powerful engines, and you are exactly right transfer flow aiming is key....
    if anyone is seriously interested in two stroke engine theory I strongly suggest reading:
    Design and Simulation of Two-Stroke Engines -Gordon P. Blair
    comparing racing engines of the 60's-70's to modern times you seen this general trend: crankcase compression has gone down, transfer and exhaust port flow area has gone way up, transfer flow aiming and streaming has improved significantly, and expansion chambers have become better. Crankshaft, piston, and head design is nearly identical.
    Mar 2012
    central coast, California
    92
    Your plan for how to make the core box is spot on. Establish the parting line on your cores and then make what is sometimes referred to as a follow board, basically just a scrap board that you cut as close to the profile and then smear bondo on it and smoosh it against the part (using mold release of course). depending on the shape and size sometimes I will drill a hole a 1/2" or even a couple of holes and pour the urethane from the back side.
    Don't forget to plan the core prints for your cores before you make the core boxes. This is also the point where you will want to decide how you're going to pour the cylinder, horizontal or vertical. If your using chem bond for the mold I would go with vertical but if you're using green sand I would probably go with horizontal unless you are using cores to get the fins in which case I would pour it vertical. Once you get the orientation sorted out you need to decide how you want to place and secure your cores. Is everything going to just sit in the drag or are the transfer port cores also going to have a print that sits in the cylinder core? will the transfer port cores be glued to the cylinder core using a jig and then set as a one piece core or will they be dropped in one at a time? If the later you need to do a full scale cross sectional layout of a transfer core and the cylinder core to make sure the draft on the prints will allow you to set the core in place, donít forget to draw the fins.
    Back to the cores and the prints. As you can probably tell I would lean towards a print on each end of the transfer port core, but either way I would pour the urethane without the print attached and make that part of the box as a removable piece which will essentially look like a frame. Depending on how you part the core you could potentially have problems with the prints being at 90* to each other so for that reason one or both prints may need to be smaller than the part where they meet up, hence the separate removable piece for the print portion of the core box which would eliminate any shoulders that would lock the core in the box due to the 90* orientation of the prints.
    I would also leave the tops of both prints open, in other words the core box will have two openings. you can always clamp a board over one opening but on small curved cores like that you might need to pack it from each end.
    I know the deck height can be machined to change the port timing but my understanding is that you want the transfer ports to all have the same top and bottom heights relative to each other. For this reason I would be inclined to have at least a shallow print in the cylinder core and if you want to glue them up and drop them in as a single core then you need a bit larger print.
    The box for the cylinder core will be the more complicated of the boxes. It will be split on the center line with one print in one half and the other two prints in the other half. the half with two will be a box with two large loose pieces with split being on the center line, i.e. the entire mold surface on that half of the box is formed by the two loose pieces vs. having only the prints being loose pieces. If I haven't explained this part very well I can make a couple of sketches.
    Thanks J, for the explanation and for the book recommendation - I'm half-heartedly thinking about getting a small 2-stroke bike (350LC perhaps, or a 250 Gamma?) for Sunday morning Hooligan rides, and I like to know the Inner Workings of my machines Do you have the ISBN off the cover of the book I can use to look it up, see how extraordinarily pricey it is?
    Dave H. (the other one)
    Dec 2014
    San Francisco, USA
    53
    Thanks again for the advice Bluerider. I have been enjoying our discussion about wood and reading the related wood thread you started...
    I have seen cylinders done where the transfer port cores have prints on both ends.
    My approach was going to cast the cylinder vertical in a chem bond mold, the transfer ports will have prints on the bottom that serve three purposes: 1) aligning the port with the cylinders axis, 2) setting the port window and deck height (yes all three need to be the same), 3) molding the lower portion of the port into the cylinder "liner skirt" (the portion below the deck).
    I was planning to use a simple rod shaped core for the cylinder core with no prints for where the transfers attach. But with a step used against the core prints to set the port heights. The cores would be glued together and dropped into the sand mold as one piece. Or the sand mold would be the actual fixture used to glue the cores together.
    When I go to make the pattern I will first make the entire core structure with prints (probably from urethane castings made from the actual core boxes) and build the pattern around that, this way I can insure that the prints will be in workable positions in the sand mold...
    Will be posting some progress soon!
    May 2008
    in the fog of San Francisco
    346
    Dave, you might also look at
    http://iheartstella.com/resources/ma...nce-Tuning.pdf
    and
    http://www.amrca.com/tech/tuners.pdf
    for the 2T books by A. G. Bell and Gordon Jennings. The price is right.
    cheers,
    Michael
    Dec 2014
    San Francisco, USA
    53
    I pulled these of amazon form Blair's book:
    ISBN-13: 978-1560916857
    ISBN-10: 1560916850
    I think A.G. Bell's book that Michael posted above is probably the most fun to read of the three, and explains two stroke tech/tuning very well, but leaves a lot to be desired in terms of "what exactly to do", if you want to apply the knowledge.
    Jennings is getting a bit dated but there is still a lot of great information in there, and some of it is timeless, either of those books is a better read for the basic understanding, then Blair.
    Jennings offers quantitate solutions to tuning, I actually drew the engine geometry and calculated port time areas on graph paper for the first motor I ported and designed a tuned pipe for it after reading Jennings.
    If you really want to design an engine study Blair's work, but it is very dry and technical and will put you to sleep if you aren't interested in the hard core math to predict how an engine works.
    This one can take years to understand :-)
    Dec 2014
    San Francisco, USA
    53
    Holiday business has been slowing my progress this week so minimal progress to report but there has been some. I need to have this casting done by the first week of February to have time to have the bore plated, and be able to do some test and tune on the bike before its first race in New Orleans in March, so plan to see me get busy!
    Here are some photo updates of the project…
    Demolding the silicone transfer port mold….
    Tools of the trade, I like how this clay work can be a “kitchen table” job…
    Silicone transfer port mold showing the lower cylinder-deck face where the transfer port windows will meet the crank case…
    Here are some urethane copies of the transfer ports that were cast from the silicone mold. These are just for reference and will not be used to make core boxes. Urethane copies cast with integral core prints and the missing “cylinder liner-skirt” face will be cast next, and those will be tuned up a bit with bondo and sanding, then used to make the core boxes…
    A load of rough sawn, dry, poplar stock for the pattern shop, following Bluerider’s wood advice:
    http://www.alloyavenue.com/vb/showth...-patternmaking
    Now he has me wanting an 18” disk sander, but I priced the good ones and they seem to weigh in at about $2-3k new and $1k used! Crap, seems like such a simple tool, but expensive! Although I LOVE my basic 6” belt sander it is worth its weight in gold and I am sure the big disk would be too….
    More fun with silicone and urethane: these are the “Henise mold alignment button Model 1”
    You can see the machined aluminum version of them in this pattern and sand mold… Making these urethane castings sure beats running the lathe!
    That story published here:
    http://www.alloyavenue.com/vb/showth...ns-to-castings
    3,625
    I love seeing your images - its clear you are skilled when it comes to pattern making and fabrication. Thanks for posting. I hope the holidays dont slow you down too much, I am enjoying the ride thus far!
    Dec 2014
    San Francisco, USA
    53
    Progress to report!!
    here is a pattern made from aluminum to model the cylinder liner-skirts portion of the transfer ports...
    here is how the liner skirt pattern will be used with the silicone mold of the port passages...
    this shows the five-piece mold that will be used to make a urethane casting of the transfer port passage with the liner-skirt portion and integral "core print"...
    wax fillets were used to get rounded corners on the core print...
    A urethane pour...
    transfer port castings with core prints after a little sanding to smooth...
    Here are the transfer port core patterns after a little polyester tune up, also shown is the exhaust port pattern with core made from foam...
    and finally all of the port-core patterns after all sanding smoothing and given a coat of primer for final smoothness...
    Dec 2014
    San Francisco, USA
    53
    After the core pattern exist, core boxes must exist...
    Poplar halves that will for the exhaust port core box...
    Wood, bondo, and clay are used to make a follower board and establish the parting line...
    After pouring urethane and demolding a core box section exists...
    Setting up to pour the top insert, this one used a sprue and riser though the board...
    the super-awesome 20" "pattern makers" sander in action...
    Setting up follower boards for the main transfer port core-patterns...
    Bondo and clay are used to build the irregular parting line...
    here you can see the wooden core box, urethane facing (grey), core pattern (black) and sacrificial bondo (pink polyester) follower to make the parting line...
    More core box parts, patterns, and followers...
    And some more urethane pours...
