Page 5 of 9 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 82
Thread: 1931 Model A Victoria build
  1. #41
    2,619
    Here is the completed model...
  2. #42
    2,619
    managed to get the sheet metal epoxy primed....
    and picked up an intake for the v8 60 and working on polishing it while I drink some beers....
  3. #43
    2,619
    So that stupid lil emblem is kicking my butt!! I machined out a pattern in wax and took a mold from it, but getting the .010" wide text to come out is impossible. The wax just does not like to fill the cavity, and when it actually does it usually breaks off. So I tried milling one in brass it went ok but snapped the endmill before i finished. My mills spindle speed is limiting me on this project, so I decided to add on a auxiliary spindle that can wind up to 30,000 rpms. Being on a budget meant that the kress spindle ($300.00) was not an option. Searching the local stores I found a Makita RT0701c router trimmer that seemed well suited for the task, but was only supplied with a 1/4" collet. I searched the net for a bit and found a gentleman who offers different size collets at a reasonable cost. http://www.elairecorp.com/makitaroutercollets.html
    Ok now were getting somewhere!! So I ordered the collets and went back to Home depo spending just $89.00 and came home with a very nice piece of equipment. I modeled up a bracket, machined it out, and fitted it to the mill. Now I sit here waiting on the collet to arrive....Bummer....
  4. #44
    2,619
    I went ahead and played around with the enameling on the unfinished brass that I broke the end mill on....Hopefully this gives some idea of what I am attempting to do. Dont mind the scratch, when I actually get things right I will be chrome plating them after machining....
  5. #45
    Man that's going to look the dogs danglies
  6. #46
    2,619
    Still having a couple problems to sort out, but am getting really close. These have to be perfect!!
  7. #47
    2,619
    I know it doesnt look like much, but it took me quite a bit of time to whittle it out. One more step forward....now when is that new mill showing up?
    V8-60 valve guide pilot
  8. #48
    Apr 2016
    Adelaide Sth Australia
    82
    Beautifully made David, those guides bring back many memories.
  9. #49
    2,619
    New tool works like a champ. I had some very deep pitting on a couple of seats that I was concerned about having to put a new seat into, but fortunately they cleaned up. I need to order a couple more stones so I can make the top and bottom cuts but for now Im a happy guy.......Now back to work on the cylinder head patterns........
  10. #50
    Very nice seat there
