Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 29
Thread: Project: Precision Vise
    That turned out purity nice. Now you need to make one out of a good quality steel
    Many years ago (when I was working) I made myself a tool makers vice similar to yours out of tool steel, I even had it heat treated, then precision ground it so it's square, parallel, I still use it when doing certain kinds of work, it will come in handy once I get my universal surface grinder up & running
    Ron
    If ya cant cast it, Forge it RSS
    http://metalmaster1766.webs.com/
    Senior Member caster's Avatar
    New Jersey, USA
    511
    I got lots of progress, I finished the base and gave it its first sanding and a bit of polish and milled the slider to size. I still need to get the screw mechanism installed.
    Caster
    Apr 2015
    Huntsville, AL, USA
    155
    Do you have the screw already? I've got a wood vise screw that I'm not using. 1-3/8", I think. ACME threads.
    Jun 2008
    in the fog of San Francisco
    346
    You may want to look into having the parts hard anodized to reduce the wear as they move against each other.
    New Jersey, USA
    511
    Yes, it would be a good idea to harden the cast aluminum, it really should have been made of cast iron (I'm not there yet maybe by next summer).
    Thanks you daggs, very generous offer. The vise is designed to use 3/8-16 screw. I roughed the fit, next I need to turn a 5/8" steel rod to go inside the slider. Thanks again.
    Caster
    Coming along nicely.
    New Jersey, USA
    511
    Got the screw mechanism done, now a little chamfering and polishing and its ready for all the abuse I will throw at it.
    Caster
    Jun 2011
    Northern Kentucky
    1,148
    That looks beautiful! Nice work! I've dreamed of making a vice for my drill press, and this is almost inspiring enough to make me abandon my current project and start a new one... But no, I'm trying to get better at finishing what I start...
    Alloy Avenue Member Map
    New Jersey, USA
    511
    Thanks, Its been a year in the making. I left some surface pitting, did not want to mill it smaller.
    Caster
    New Jersey, USA
    511
    I did not have a precise worked out design when I started this project. I knew what had to be square, perpendicular or parallel but I did not have predefined dimensions to work to. The original drawing did not have removable jaws but I knew I would add them later, now is later. I measure the slider and notice that I only had 3/16" between the face and the tension rod, that is not enough to securely hold the jaw. You got to love a foundry, I altered the pattern added 3/8" making it thicker now I can drill and tap, I recasted.
    I get such a feeling of satisfaction when I make something useful. I used the vise to machine the new slider.
    I didn't have time to finish the slider but I roughed it and its square, the vise actually does what I hoped it would do.
    Caster
