Page 3 of 3 FirstFirst 123
Results 21 to 25 of 25
Thread: a hacksaw for aluminum cutting
    2,701
    Glad to hear from you Nudge.
    I've cut on my table saw a number of times with good results. I just used a carbide blade but I can see where the special blade would be worth the investment if it gets used enough. I always make sure all of the wood sawdust is gone before I start. I've also found that if I only cut 75-90% through I can easily break it with a 2lb hammer plus I don't get blasted with chips.
    I recently bought a metal cutting bandsaw off Craigslist for $75
    It has saved me a lot of hacksawing on both aluminum and steel. It cuts steel better than aluminum. I get some jamming. Tryphons latest post has convinced me that a coarser blade would do the trick.
    923
    Nudge, that's serious cutting I don't imagine doing that by hand!
    The first picture in the first post the blade looks like a wider hack saw blade than a band saw blade.
    Working on a Hydraulic log splitter at the moment, It's not going to get used for just logs!!!
    The only time You're not following your nose is when your going backward!.......Andy (ME) .
    Have you filed in "Who do you think you are?" "War Grade Report" " My photo's"
    Senior Member nudge's Avatar
    Sep 2005
    NorthShore,Auckland New Zealand
    5,080
    Yup! It won't matter how good your hacksaw is, cutting an engine head it two would be a workout!
    If the spelins rong blam the wife!
    How to build a Nudge burner (oil)
